Leaking Model L water pump
dlp
03-28-2004 08:59:32
Does anyone know of a replacement seal that would work, without buying the whole pump?
Casenut
03-28-2004 16:44:52
 Re: Leaking Model L water pump in reply to dlp, 03-28-2004 08:59:32
If it is like my 29 L (which has the flat belt) there is a packing nut that can be tightened or take the nut off and install some graphite rope and tighten (don't make it too tight though)
Kennyp
03-28-2004 15:32:24
Don't know if it will help but, years ago I bought a "kit' for my LA from Case dealer. Had a seal. I was told to not have the impeller tight to the shaft. It was on a pin and needed to move to align against the seal.
Robert Pence
03-28-2004 09:32:38
My L (1937) doesn't have a seal, that I recall. I had the pump out about six years ago. The shaft runs through a long bushing, probably bronze, that is a close fit, and the grease is all that keeps it from leaking. Apparently the hydrodynamics keep it from leaking when the engine is running, and when I shut it off, I just turn the grease cup down enough to fill the space between the bushing and shaft. It helps to turn the fan while screwing down the grease cup, to distribute the grease. If I do this, leakage while not running is negligible.
Allan C
03-28-2004 20:20:41
 Re: Re: Leaking Model L water pump in reply to Robert Pence, 03-28-2004 09:32:38
If I reccolect the "seal" is a metal cap that runs against the wall of the pump casting. There is no seal in the conventional sense. I don't remember having a problem with them leaking either.
