Case VAC
J.Fox
03-28-2004 04:03:34
What would the problem be if there were grinding in 3rd and reverse? how could I fix it?
mj
03-28-2004 23:10:38
 Re: Case VAC in reply to J.Fox, 03-28-2004 04:03:34
Could be: Not enough grease, gears could be worn on splines, bearings broken, shift fork bent or gears improperly spaced on shaft. Pull the cover and see if you can tell what's FUBAR. If you can't tell this way get ready for a transmission teardown.
