Loader help
Jeff
03-27-2004 19:10:17
I just installed a Bush Hog loader on my 1194 case and had to connect to the rear remote outlets. I have to tie the remote lever back to operate the loader, and when I do this, the three point doesn't operate until the remote lever is back in the neutral position which doesn't let the loader operate. I need to find out how to plumb the loader so it has fluid all the time and not through the remotes on this tractor. If someone on here knows, or has one of these tractors with a loader, I would appreciate any help.
Thanks, Jeff
Roger
03-27-2004 19:36:51
 Re: Loader help in reply to Jeff, 03-27-2004 19:10:17
Jeff, I have a 930 with a loader on it, I have to tie one lever ahead also to run the loader. I have a separate 3 valve group above & to the right of the gauges otherwise I would have all of the remote outlets tied up. I don't think there is a way to do what you are thinking of. I have to kick the one lever back to neutral to use the other outlet. I think it's something we'll just have to live with.
DKase
03-28-2004 09:24:12
 Re: Re: Loader help in reply to Roger, 03-27-2004 19:36:51
On the 930 you just get a good hyd. hose made to plumb your loader valve in what is now the steel pipe from the pump to the tractor remote valve.
