dctom ? re L Case
JW
03-27-2004 17:32:48
The SN on my L case is L317983. I believe that's a '37. Early photos show steel on rear and rubber on front. Does your info show if that was original. All available info will be greatly appreciated.
Bill
03-28-2004 06:53:26
 Re: dctom ? re L Case in reply to JW, 03-27-2004 17:32:48
JW. On the seven digit serial numbers on the letter model cases you take the first and fourth number and substact 3 from them such L317983--- 39 minus 3 means a 1936 year hope this helps Bill
Bill
03-28-2004 13:47:45
 Re: Re: dctom ? re L Case in reply to Bill, 03-28-2004 06:53:26
I stand corrected, Six digit number not the seven, seven digit numbers starting in 1938 you subtract four from the first two numbers,Thanks Brian for the correction. Bill
Brian in Ohio
03-28-2004 10:33:01
You mean the 6 digit serial number, not seven. Seven digits, you take the first two and subtract 4.
Your math was correct, but you basically said it backwards...
dctom
03-28-2004 05:55:45
J W I DONT HAVE ANY INFO OF 1936 TRACTORS, BUT IN THAT TIME FRAME COMPANYS WERE BUTTING RUBBER ON FRONT AND NOT ON THE REAR, STEEL ON FRONT WAS TERRIABLE HARD ON WHEEL BEARINGS AND REAR TIRES DIDNT PULL GOOD THAN SORRY TOM
caseman-d
03-27-2004 21:28:32
If I did my math right it should be a 36 model.
caseman-d
JW
03-28-2004 06:42:54
 Re: Re: dctom ? re L Case in reply to caseman-d, 03-27-2004 21:28:32
How did you determine it's a '36?
The SN charts I see including this website shows that '37 Model L, starts with SN 30401. Wouldn't this be a '37 with a SN of 317983?
