DC BELT PULLEY REMOVAL
Dave S
03-27-2004 16:17:28
How do you get the belt pulley off a DC? I removed the four bolts and the plate, do you have to remove the nut in the center? Whats the grease zerk for? Thanks, Dave S
C. Amick
03-29-2004 13:30:22
 Re: DC BELT PULLEY REMOVAL in reply to Dave S, 03-27-2004 16:17:28
If your not in a hurry, put some PB Blaster on it and use the tractor with the bolts removed. It should work loose.
Glenn FitzGerald
03-27-2004 20:57:28
I haven't looked at mine recently but I've had it off before. My DC is a late model eagle hitch one, if that matters. As I remember it, I just removed that rather large disk in the center by removing the four bolts. I think it took a 9/16" wrench. The pulley is on a shaft with four rubber 'rods' which fit in groves in the pulley and the base. With the four bolts removed the pulley came off with little trouble. Had mine off for a while and decided I liked the looks of the tractor better with it on. Glenn F.
dctom
03-27-2004 16:34:54
YOU DONT HAVE TO REMOVE THE BIG NUT, IF YOU REMOVED 4 BIG CAP SCREWS IT SHOULD COME OFF IF YOU HAVE THE RESILIANT PULLY REMOVE THE SMALLER CAP SCREWS AND PULL IT OFF THE HUB, MAYBE RUSTED ON SOME BUT SHOULD COME OFF WITH A LITTLE FORCE
