310 crawler engine
Neil Bresett
03-27-2004 08:02:52
I found a 310 crawler and a 310 tractor. the crawler needs a running motor. my question is will the engine from the tractor bolt into the crawler frame. the other option I have is to rebuild the motor in the crawler. both are gas i belive 148 cid.
Russ
03-28-2004 12:09:43
 Re: 310 crawler engine in reply to Neil Bresett , 03-27-2004 08:02:52
Neil; If you have the time and money rebuild the 310 crawler engine. Good luck.
mikes'600
03-28-2004 05:25:51
I have the three bolt starter set up(148) if you need it.thanks
george md
03-27-2004 11:01:30
Neil, Build the crawler engine , it would be a crime to destroy a 310 tractor for parts. 310 is a great little tractor .
george
Neil Bresett
03-27-2004 16:36:05
 Re: Re: 310 crawler engine in reply to george md, 03-27-2004 11:01:30
If I buy the tractor and the crawler i would eventually rebuild the motor to put back in the tractor.
martin in DE.
03-27-2004 08:19:46
Neil,310 crawlers used two different 148cid engines depending on model, c,d,e etc.The small crank engine has a two bolt starter like the 310 wheel tractor. the large crank engine has a three bolt starter like a430 wheel tractor. regards martin
