Unsticking those stuck engines? NOT
Klyde
03-26-2004 21:12:11
Was working on a stuck engine last couple days and did not want to take the head off. Let it soak 2 days with p-oil and then tried my usual bang them loose trick.Thats oxy-ac mix in the spark plug hole and then quick screw in the spark plug,hook up the plug to a coil and make the spark. This usually loosens them up pretty quick,1 cyl at a time, with the rockers off and all valves shut. Well it didn't work! BRAINSTORM , I made an adapter for the sparkplug hole to hook up my porta-
power and pump oil into the cylinder. WORKED GREAT TILL today. Had moved 3 down all the way down and swiched to 1 (suck oil out of cyl after taking adapter out) put one down as far as it would go (not all the way) then switched to 2. 2 went down easy as pie all the way.(this is getting messy oil everywhere) Went to number 4 pumped that down as far is it would go easily AND THEN GAVE IT ONE MORE PUMP BANG now I have antifreeze in the cylinder and running out the oil pan. SO now I can pull the head and see if I blew the head gasket, cracked the head, or split the block. (dry sleeve binder engine) you dont think I would have done this to a CASE. So what do you think I screwed up???
fixerupper
03-27-2004 16:04:02
 Re: Unsticking those stuck engines? NOT in reply to Klyde, 03-26-2004 21:12:11
The porta-power sounds like a good idea. It will pump in a little at a time. I unstuck a Farmall Regular once by screwing a hydraulic hose in a spark plug hole and plugging the hose into the hydraulics on my J.D. A. It did push the piston down to the bottom but it pushed it down faster than I wanted it to. I still had diesel fuel in the other cylinders and when the other pistons came up they shot diesel fuel out of the spark plug holes and all over the wall of my shop. It's good I wasn't standing there. I'm going to go out to the shed and try my porta power on an F20 that has been soaking for a year to see if something happens.
allisguy
03-27-2004 08:54:51
Klyde, The job was finished after getting the first piston to move. Why did you continue to mess with it?
Klyde
03-27-2004 23:27:49
 Re: Re: Unsticking those stuck engines? NOT in reply to allisguy, 03-27-2004 08:54:51
Well I thought it was finished too, cept you still can't turn it. Had a bar in the flywheel an everything.
ted
03-27-2004 00:17:36
Klyde, that's a pretty sharp idea! Best I've heard. Thank you! Now, one quick question. Do you unbolt all the rods before you do this? You must, or when one moved they'd all move. Right?
Klyde
03-27-2004 03:59:20
 Re: Re: Unsticking those stuck engines? NOT in reply to ted, 03-27-2004 00:17:36
Yes, they all move at the same time and they are still connected to the crank
Mike Schotte
03-27-2004 00:09:55
Hi Klyde,
Well- you would certainly HOPE that the head gasket is the weakest of the three items involved! Good luck.
Hope it works out for you. Before I finished reading your post- I was afraid you were going to say you left one cylinder full of oil while you put pressure on the next one...
-Schotte
