VAC water pump-HELP!
Brian
03-26-2004 19:12:06
The water pump out of my 1946 needs a new shaft and impeller as well as the bearings/seals. Are these parts available or where can obtain a direct replacement water pump? The pump casting # is Y400K-335 T2. Spring tillage is coming up and I need to get this beast together!!!
Thanks
JR(CASE38MAN)
03-26-2004 19:38:13
 Re: VAC water pump-HELP! in reply to Brian, 03-26-2004 19:12:06
E-MAIL ME IT IS OPEN
Richard Shackelford
03-27-2004 05:02:28
 Re: Re: VAC water pump-HELP! in reply to JR(CASE38MAN), 03-26-2004 19:38:13
I needed a brake drum for my vac 1952 and called a ed axthelm in ohio @ 419-864-4959.He sent me the parts i needed.He is a very nice gentleman and i am sure he can help you out by either having the part or putting you in the right direction....Good luck...Richard oh yeah best to call in the evening(between 8:30 and 9:00)
