Bob KY SC Valve Stem Seals
L.Lamp
03-26-2004 18:15:47
Take the valve cover off and see if the oil feed tube going up to the rocker arm shafts is sealing in the little cast iron piece. I had an SC that the orfice in the oil feed tube was gone and the fit over the oil supply tube was very poor. It sprayed oil the full length of the valve cover. It couldn't help but suck in oil. You never know how some people "fix things".
Bob KY
03-28-2004 18:15:07
 Re: Bob KY SC Valve Stem Seals in reply to L.Lamp, 03-26-2004 18:15:47
Thanks for the info- I'll be sure to take off the valve cover and check that out. I hope that's the only problem...
