VAC transmission
tomturkey
03-26-2004 06:37:34
Reverse idler gear is bad as well as the bushing and I believe the shaft. The shifting yoke is worn because of the wobblie gear. What is the best/easiest manner to fix. Secure a total tranny casting with all intact, or pull out the bad and find good to replace. I am not very confident about removing all the shafts gears seals etc and ending up with a working transmission. Thanks in advance for all who comment
steve from PA
03-26-2004 13:13:48
 Re: VAC transmission in reply to tomturkey, 03-26-2004 06:37:34
Where are you located? I may have a tranny for your VAC. It's out of a '47 VAC.
mike's600
03-26-2004 16:54:33
 Re: Re: VAC transmission in reply to steve from PA, 03-26-2004 13:13:48
hey i have a couple of trans 48, vac ,Vai take your pick. Complete and good.
Just doing some spring cleaning!!
tomturkey
03-29-2004 11:51:16
 Re: Re: Re: VAC transmission in reply to mike's600, 03-26-2004 16:54:33
Steve from Pa. and Mike's 600 e-mail Hagen [email protected]. Pa is along ways from Iowa, let me check on something more local give me a e-mail address and I can get back to both of you. Thank s for responding tomturkey
