VAC slow to start
carl from nebra
03-24-2004 08:24:02
I have a 53 VAC that I've had for years. It's always been a super slow cranker. It has the original 6 volt system and fully charged it still barely turns over and will not if hot. What can I do to speed it up?
andy
03-26-2004 17:44:10
 Re: VAC slow to start in reply to carl from nebraska , 03-24-2004 08:24:02
Your problem might not be the starting system. Six volt systems always are slow to turn over, especially in colder weather. When the engine is hot and will barley turn over it is some times because the timing is to far advanced. The plugs are firing before the pistons reach top dead center on the compression stroke. Try moving the distributor a little.
GeoMO
03-25-2004 14:38:21
My 51 was always hard to start with 6V.
I could start it with a hand crank with 1 to 3 half turns.
I changed it to 12V and it starts great.
All batteries are not equal. Look at the cranking amps.
C. Amick
03-24-2004 09:23:33
Make sure you have a good ground and perhaps increase the size of the battery cables. I think they are supposed to be #2 cables. I have even used a #1 cable.
Steve in Md
03-24-2004 09:10:08
The assumption is that your battery is in good condition and being fully charged by the generator (ie. putting out 6-7 volts to the battery). You might want to check all the connections to and from the battery and starter motor for corosion and/or resistance. If that doesn't help then perhaps a check needs to be made on the starter motor for excessive current draw. The starter motor may need to be cleaned and overhauled and/or bushings replaced.
mj
03-25-2004 16:18:58
 Re: Re: VAC slow to start in reply to Steve in Md, 03-24-2004 09:10:08
Roger all of that! The starter motor in particular never seems to get any TLC....just R&R'd when it finally craps out.
chopper
03-24-2004 19:03:41
also make sure your plug wires or wire is not grounding out on any metal. it happened to me and when i tried to start in dark i noticed a blue spark and saw i had a wire on pare metal
