69 Case 580CK TLB manual clutch, 188D, splitting t
jim
03-24-2004 04:45:55
I only have to push in the clutch pedal 1/8" before engaging the clutch w/ no more adjustment, so I guess it's time to split it & replace the clutch, right? Assuming I need to replace all wear items, cause it very well may be original, what's the approx total $$$ for parts? How far does it need to separate to get everything in & out ok? Is stuff going to fall out or start flying out? That would be very bad for me since I need to see how it comes out if I'm going to get it to go back in the same way it came apart? There's no ROPS on it. I read in a post you keep the hoe & loader on which I'm doing. I'm doing this outside so I was planning on laying down 4' long 1/4" thick steel sheet panels to set the floor jack & 2 front wheels on so it rolls the engine forward easily. Do you use really long thread bolt to slowly close the engine & tranny back together? I guess there's some flywheel seal alignment that needs to be watched on re-assembly? Is it really imperative that you keep engine/flywheel aligned w/ long pins, after disassembly cause I figure between incrementally raising/lowering the floor jack, it shouldn't be a problem to get things lined back up again, right or wrong?
Thanks
Jim
Roger (Mi)
03-26-2004 05:52:35
 Re: 69 Case 580CK TLB manual clutch, 188D, splitti in reply to jim, 03-24-2004 04:45:55
As a former Case mechanic, another fellow and I were changing so many clutches in 580's, that we could disassemble and assemble the 580 with all new clutch parts (parts were already on hand) in less than 2 hours. Don't expect to do it yourself in that time. No parts are going to fall out when you split the 580 unless it's broken parts. You only need to split the 580 by a couple feet to change all the necessary parts. Once split, if the rear main oil seal shows evidence of leaking, change it. Remove the grill, remove the two side inlet hoses going to the hydraulic pump, use a pipe wench to unscrew/remove the two pipe nipples going to the two loader side frames. That will allow the front part of the 580 to be moved forward when it's split. From that point on, it's just unhooking the obvious, i.e. removing the hood, power steering lines at the pump, fuel lines, electrical wires, starter, etc. Use a hydraulic jack to support the torque tube. You'll need a floor jack (wood block between the floor jack and oil pan) to roll the front of the 580 away from the torque tube. Use two small wood blocks (each side) between the front axle and the motor frame to keep the motor from tipping on the axle when it's split. When reassembling, make sure you use a good clutch disk alignment tool or you'll NOT be able to get the 580 back together again. Good luck.
Redd
03-25-2004 09:15:18
Interesting questions Jim as I have the same tractor so I'd sure like to see some experienced replies . I need to replace my clutch, fix the oil leak at the trans/diff. housing and probably do some ring and pinion work. I'm going to drop the backhoe and loader plus pull the ROP so I can put it in the shop on a cement floor. Just dont feel safe being outside in the dirt or weather if it becomes a project. Ive been told twice to go ahead and put in an industrial (metal) clutch as long as I'm doing it . Cost for parts and refurbishing the fly wheel and pressure plate about $500. I'd like to know what common problems there were with the differential and what to expect if anyone can help.
jim maloney
03-29-2004 08:55:01
 Re: Re: 69 Case 580CK TLB manual clutch, 188D, spl in reply to Redd, 03-25-2004 09:15:18
Thanks so much for the reply. This is so helpful. I am going to do it in about 1 month. I'll let you know how it turns out. Hopefully I won't have to do it twice. Lately this seems to be the way I do things. Live & learn I guess. I though it was a piece of cake dropping the backhoe & re-attaching it but other's say it's a pain, I didn't have any problems. I did it a couple of times. I had no idea it was that expensive, wow. how much for this alignment tool, I guess all Case dealers would know what I'm talking about there right?
Thanks
