Case 830 Tractor Won't Start
Rick
03-23-2004 18:21:03
Oct.2003 I started having an engine starting problem. Sometimes after 3 or 4 attempts the engine would turn over & start. The tractor sat in the barn all winter, now when I try to start the engine the starter solenoid cliks & thats it, engine doesn't turn over. So far this month I have a new battery rated at 925CCA, new Case starter solenoid with spring, new #2 cable from the battery to starter solenoid, new #1 cable from the battery to ground, battery connections have been cleaned & all the wire ring terminals that connect to the starter solenoid have been replaced. Any next step suggestions would be appreciated.
JJ (WI)
03-23-2004 18:39:11
 Re: Case 830 Tractor Won't Start in reply to Rick, 03-23-2004 18:21:03
Well first thing I would do is check the seleniod make sure that when it closes you have continuity from input side to starter side, if you do then the problem lies in the starter. Then I would pull the starter could be hung brushes witch is a simple fix by cleaning and using a silicon based dry lubricant, could be bad fields in the starter, once you get it out do a "no load" test by useing a battery. Connect the ground to the starter case and carefully touch the pos to the input lug on the starter, doing this in a vise is wise because the torque of the starter turning can hurt you. If it seems to be laboring to turn it needs to be rebuilt, but if it winds up good and throws the bendix out fine then its something in the wiring on the machine perhaps the ground isnt getting freely to the starter.
Anyway thats my thoughts hope it helps
JJ
jstpa
03-23-2004 20:16:43
 Re: Re: Case 830 Tractor Won't Start in reply to JJ (WI), 03-23-2004 18:39:11
Rick,
The only thing I would add to what jj said, would be take it to a rebuilder once you get it off, and let them check it out, even if it runs good on the no load test.Where I work it seems at least 50% of the starters will bench test alright even though they won't start the vehicle.
good luck, jstpa
Allan c
03-24-2004 21:06:00
 Re: Re: Re: Case 830 Tractor Won't Start in reply to jstpa, 03-23-2004 20:16:43
Did you check that the engine turns over easily?Had a Cockshutt once that piled a bearing and wouldn't start either. - too tight to turn.
