case 611-B
jason
03-23-2004 17:30:25
just bought a 611-b and noticed it has hydrualic or transmission oil dripping from where the engine bolts to the bell housing i see it has a gasket in between there. should there be oil in the bell housing and how much. it has the case-o-matic transmission in it also.also i did notice the bottom two bell housing bolts were a little loose. any info would help thanks jason
John
03-24-2004 13:09:35
 Re: case 611-B in reply to jason , 03-23-2004 17:30:25
Yes. That is where the torque convertor is. There is actually a whole bunch of oil in there. You will get quite a splash if you take out the timing plug to check timing while it is running! Good luck.
JASON
03-24-2004 15:57:35
 Re: Re: case 611-B in reply to John, 03-24-2004 13:09:35
THANKS ALOT JOHN, just ordered a new gasket for it today. got it split in half this afternoon too.
