2090 Case starting
tom
03-23-2004 08:33:31
i have to short across two electric posts on a ? relay or switch? (mounted on right side of engine behind batteries.....to start the tractor...what is this small relay?? a saftey feature? what is the part that i need called??
tom
03-24-2004 07:51:49
 Re: 2090 Case starting in reply to tom, 03-23-2004 08:33:31
thanks a lot for the very helpful information...will go ahead and get a new solenoid
turbo
03-23-2004 17:33:21
178149A1 is the part # for that solenoid. It is a relay solenoid that decreases the load on the starting and saftety circuit to activate the main starter solenoid.
ketch
03-23-2004 09:21:29
The switch thats in question,located near your shift linkage are neutral safty switches,should be two of them.Most have shims underneath to remove or add to adjust your switch to work when the trans.is in neutral,you can check continuity with an ohm meter when switch is adjusted right..The way the starting circuit works is when the key is turned to the start position,power goes from the key switch,through neutral safety switches;then to an intermediate solenoid(round black solenoid located on a panel underneath the starter).,then is relayed to the main starter solenoid.Please discourage shorting these switches as a large number of people have been run over as they forget to leave the trans in neutral.Always think safety....Thanks
