Case 930
J Kelnhofer
03-23-2004 07:12:03
Hello, does anyone know where to check the hydraulic/transmission fluid on a 930 CK? This is my new tractor and I do not have a manual yet. Thanks
DKase
03-23-2004 12:27:03
 Re: Case 930 in reply to J Kelnhofer, 03-23-2004 07:12:03
Just to the left of the PTO shaft on the back of the tractor if it is an 8 speed. If it is a 6 speed there is a check plug on the rear housing somewhere. It has been a long time since I worked on one of these. Post again if you need more info. I have one junked out in the trees. DK
J Kelnhofer
03-23-2004 16:18:21
 Re: Re: Case 930 in reply to DKase, 03-23-2004 12:27:03
I'm sorry, I meant air intake.
J Kelnhofer
03-23-2004 14:20:23
Thanks alot DKase, I was not sure if that was not just a breather. Does that 930 happen to have the above hood air cleaner? I am in need of one, if you do just post here or email me at [email protected]
BasketCASE
03-23-2004 14:13:32
Hey DKase, is your junked 930 a 6 or 8 speed? If it's a 6 I may need a part.
DKase
03-23-2004 19:02:48
 Re: Re: Re: Case 930 in reply to BasketCASE, 03-23-2004 14:13:32
It is a 6 speed and the pre cleaner air filter has been used on another tractor.
