thermastat question
case kid
03-22-2004 18:59:34
I have a 1950 case dc I just restored. I put a new radiator in it and a thermastat. It did not have a thermastat in it to begain with but I thought Id put one in it. Now it runs all the way up to 220 then back down to 160 then up then down untill it finilly stays at 180. It like its geting air in it. The question is would it be better just to take the thermastat out or cut the center out of it and leave it in.
Joe (Wa)
03-22-2004 21:12:14
 Re: thermastat question in reply to case kid, 03-22-2004 18:59:34
Sounds like the T-stat does not have a bleeder hole in it or it is too small or was inadvertently plugged upon assembly.
Yes, you want a thermostat in any water cooled engine.
Joe
Gene Dotson
03-22-2004 21:05:20
Sounds like the thermostat is not bypassing enough coolant to get the proper sensing to open properly. May have to drill some small holes around the outside to let water pass before the thermostat opens to maintain proper temperature... Gene
case kid
03-23-2004 15:13:29
 Re: Re: thermastat question in reply to Gene Dotson, 03-22-2004 21:05:20
Thanks guys I'll try drilling a small hole in it, and see if that works.
