Questions on 1st tractor?
JJ (WI)
03-22-2004 16:20:33
Hello I have a few questions for you kind folks. let me start with what tractor i am looking at, it is a 55-57 Case 400 diesel. It is in perfect running order other than the 3pt wont lift. I am assuming that it is either the pump the actuating lever the valveing or screens and filters (correct me if it could be something worse). Everything is on the tractor and all the sheetmetal is straight. I can get this machine for a small amount of labor ($300 estimated worth of labor). But i would have to trailer it 300 or so miles to get it home. Its at the peoples winter home in northern Iowa. Is this a good deal? (pretty sure it is) Was this a good machine? I read all the posts on this web site i could find and got kinda vaige results. I am prolly gonna use it to make some hay. Oh and it comes with the original shop manuals for it as well. Anyway I would like as much info on this machine as You all could give me.
Thank you all so much.
Dave Cole
03-23-2004 11:19:01
 Re: Questions on 1st tractor? in reply to JJ (WI), 03-22-2004 16:20:33
I just about a Case 400 wide front gas tractor (model 411) and I paid $1000 for it.
Seems like a very nice tractor - typical Case - overbuilt.
Speaking of Case 400 tractors - does anyone have a good suggestion for a loader for this tractor?
New or used?
Dave
Dave
Gene Dotson
03-22-2004 20:49:42
JJ; If it was below freezing when you tried the lift it is possible that water has accunulated around the oil pickup screen and frozen, preventing oil getting to the pump. And yes, this is an excellent buy, or should say acquisition?.. Gene
old school
03-22-2004 17:14:41
saw a 400 sell 3 weeks ago $2200 ,300 sounds like a good dell to me.
Dean Meissner
03-22-2004 16:41:18
Yes, the 400 is a very good tractor. In my opinion, it is one of the best tractors ever built. I currently own two of them. The only major problem was with the heads cracking between the valves. It is important to idle tractor down after a heavy load. Also it is a good idea to remove the valve covers and make sure that there is't a lot of sludge sitting on top of the heads, the breathers don't do a great job of keeping the dirt out of valve area. If there is any, scrape off what you can, trying hard to keep it from falling down around pushrods. Price you mentioned is very reasonable, especially if it has a belt pulley, power steering or a factory hour meter. Good luck, Dean
JJ (WI)
03-22-2004 17:06:16
 Re: Re: Questions on 1st tractor? in reply to Dean Meissner, 03-22-2004 16:41:18
It does have the belt pully not sure on the rest I am going down in a week or so to really look it just kinda gave it a once over at first then found out they would trade it to me for labor. I will try to repost any other info on it when I get back from my thourogh inspection.
Thanks for the post
