Case 730. Power lift slow/sometime not working
birdatwork
03-22-2004 13:50:23
I have a Case 730. The lifting arms seem to be slower than they used to be and sometimes they don't work. Generally they are down and won't come up, but the other day it was just he opposite. Somebody told me it was probably a dirty filter. I called my local Case dealer and he said it was doubtful that it was the filter. He said the filter was on the return side and replacing it probably won't help.
Any suggestions? I think I will start with the filter, just so it can be eliminated.
Charley
03-25-2004 05:56:27
 Re: Case 730. Power lift slow/sometime not working in reply to birdatwork, 03-22-2004 13:50:23
My 730 had a similar problem and it ended up being a worn relief valve in the remote control unit on the rear of the tractor above the hydraulic pump. Got a rebuilt one from Elmer's Repair in Centralia, Kansas and fixed the problem.
Brent Behner
03-24-2004 17:21:58
Birdatwork. Remove Floor Plate. 3 Pt. Hitch Valve Spools & Valves Are Under Small Plate On Right SIDE OF VALVE 4 BOLTS HOLD PLATE TO VALVE 1/2 Inc. Socket Grind Outside Of Socket To Fit Bottom Bolts. Remove Plate & Rear Valve & Clean Inside Bore. Remove Domed Pistion & Lock Screw & Needle Screw & Clean Hole In Needle Screw & Outside Of Valve. Middle Ball & Spring Check Both. Front Valve Remove & Polish Outside, Don"t Move Screw. Turn Engine Over To Flush Out. Brent
