starving for fuel
pat
03-22-2004 13:00:02
gotta a db885 diesel. i have a periodic problem. when im working it and i slow it to an idle, it will run for a couple of minutes and then it quits like i shut the key off. To get it to start again, i crack a couple of lines at the top of the pump, til i get fuel, tighten them up, and it will start and run fine. two or three days or a week and it will do it again. Any ideas will be greatly appreciated.
Thanks, Pat.
Kelly MT
03-22-2004 19:24:32
 Re: starving for fuel in reply to pat, 03-22-2004 13:00:02
My 500 diesel did a similar thing. After a while it would do nothing but Idle without stopping. Turned out to be the primary filter. It has a bronze filter and it looked clean but wouldn't pass enough fuel to to work the engine. I took it out and the engine ran like a champ. I'm going to replace it with a spin on set up as I work this tractor. PK
