CASE 188 diesel questions
Mike D.
03-21-2004 17:15:43
Mine has a hole the size of my fist just behind the secondary fuel filter. The #3 rod had something to do with it.
How hard will it be to find another block?
What Case products did the 188 come in?
Any suggestions?
I feel pretty darn sad by it all.
Thanks for any help you can lend.
K-Mo
03-22-2004 04:53:33
 Re: CASE 188 diesel questions in reply to Mike D., 03-21-2004 17:15:43
Case used the 188 in many applications. I put a gas 188 in my 630 from a combine. Bolted right in. The only difference is the dipstick ended up on the opposite side.
Good luck,
K-Mo
Mike D.
03-22-2004 05:06:09
 Re: Re: CASE 188 diesel questions in reply to K-Mo, 03-22-2004 04:53:33
Are the Case 188 gas & diesel blocks interchangeable? Could I use a 188 gas block and rebuild with diesel sleeves?
martin in DE.
03-22-2004 14:07:19
 Re: Re: Re: CASE 188 diesel questions in reply to Mike D., 03-22-2004 05:06:09
Mike,the gas block in 3 main bearing while the diesel is 5. martin
Mike D.
03-22-2004 17:50:52
 Re: Re: Re: Re: CASE 188 diesel questions in reply to martin in DE., 03-22-2004 14:07:19
Thanks Martin.
I'm now on a search for either a short block or complete 188 diesel engine. No reason to downgrade to gas. Thanks for your input. Got a 188?
Mike
