Broken Crank
Keith - OR
03-19-2004 19:37:31
Friend bought a case VAC 14 serial #6000363. the guy he got it from said it started knocking so he shut it off. We pulled the pan found the oil pick up was broken off the pickup tube. So I brazed it back on for him. Then decided to find out where the knock was coming from. CRANK was broken between #2 and #3, anyone ever seen this on a Case VAC. So now we need a crank and or complete motor. Anyone know where we can locate crank or motor ???
Thanks Keith in Oregon
Ryan Slaback
03-21-2004 18:46:01
 Re: Broken Crank in reply to Keith - OR, 03-19-2004 19:37:31
Keith,
I have a crank out of a Vac engine. I was going to rebuild the engine but the pistons were froze to the sleeves etc. so i am just going to replace it. Let me know if you are interested.
[email protected]
delete .remove to get email to work.
ryan
Mike'600
03-20-2004 04:55:17
Give and email, should be able to help you out.
Thanks Mike
Keith--OR
03-20-2004 15:25:21
 Re: Re: Broken Crank in reply to Mike'600, 03-20-2004 04:55:17
Mike'600 email is posted above. Thanks for the quick response.
Keith
