Stuck valve on DC engine
okla/kans Bill
03-19-2004 17:27:14
I ave a DC engine in my Grandads CC Case. Somone dumped a bunch of water in it while I was fall plowing. I emptyed 8 bowls of water before the gas looked right in the bowl. Now, #3 valve (im guessing), sticks. Ive put in diesel and marval mystery oil in the gas along with a product to free up sticky valves, but no go. An advice. Im needing to start discing and need the tractor bad. Thanks
robert
03-20-2004 06:43:52
 Re: Stuck valve on DC engine in reply to okla/kans Bill, 03-19-2004 17:27:14
on a D I just tapped while squirtin lots of Auto tranny fluid on the sticky stems.fine vise grips to rotate around and then work it good and hot with a good heavy load...it worked..
okla/kans Bill
03-19-2004 19:17:48
How do you movethe stuck valve after taking ofdf the valve cover?? All I see is the rocker arms and push rods. How do you tap on the valves with a hammer if you cant see them, and how do you pull on it if you cant see it to get a pull with. YES, I farm with the tractor, I dont work on it. DOES IT SHOW??? LOL
Dave_D
03-19-2004 19:40:00
 Re: Re: Stuck valve on DC engine in reply to okla/kans Bill, 03-19-2004 19:17:48
The valve stem is in the middle of the spring. The rocker arm pushes it down (open) and the spring pushes it up closed. You can some times tap on the end of the push rod and free the valve. But other times the valve will go down and not come back up, as what happen on my DC case. So off came the head for a rebuild. $300 dollars later everything is now working as it should.
I think some light tapping will fix the problem. When you tap on it should make a nice clicking sound. If it sounds solid then the valve is stuck.
Good luck!
- Dave
Mike's600
03-19-2004 18:05:09
I took off the valve cover , rocker arm assem.. i found the offending valve and sprayed it with P B Blaster(penn. oil).Take a rubber hammer and tap the top of the valve, you may have to pull it up a few times, but should work loose. My DC does it from time to time.
Bob
03-19-2004 18:13:26
 Re: Re: Stuck valve on DC engine in reply to Mike's600, 03-19-2004 18:05:09
My C and one of my LAs has this problem from time to time.
I take the valve cover off and move the stuck valve with a lever or soft hammer. It sometimes takes quite a bit of work to free.
The problem I have, I am sure it is due to not using the tractors often enough.
JM
03-20-2004 03:04:23
 Re: Re: Re: Stuck valve on DC engine in reply to Bob, 03-19-2004 18:13:26
I bought an Oliver 70 some years ago. It had not been run for 2-3 years. I was advised to check the rocker arm assy. before I started it and sure enough there was a valve stuck open. I depressed the valve as far as it would go using a pry bar between the rocker arm and the end if the valve stem.It fully retracted on the first pry and has been good ever since. Maybe I got lucky, but I think running the stem through the full length of the valve guide may have cleaned a burr or obstruction. Good luck.
