Carburetor freeze
Sky
03-19-2004 16:26:15
I know it's normal for freezing to occure where the carburetor connects to the manifold on some engines, but is it normal for a '43 Case SC. It is kind of cold right now here in NH.
dctom
03-19-2004 17:15:16
 Re: Carburetor freeze in reply to Sky , 03-19-2004 16:26:15
YES IT IS AND REMEMBER THERE IS AS MUCH ICE ON THE INSIDE AS THERE IS ON THE OUTSIDE
sky
03-19-2004 17:44:17
 Re: Re: Carburetor freeze in reply to dctom, 03-19-2004 17:15:16
Thank you. Will they ever freeze to the point of choking the engine, or cause a power loss?
todd hamilton
03-19-2004 18:39:24
 Re: Re: Re: Carburetor freeze in reply to sky, 03-19-2004 17:44:17
Yes! But if you can nurse it until the block warms enough to keep the manifold warm it should smooth out and run fine.
Allan C
03-19-2004 19:23:54
 Re: Re: Re: Re: Carburetor freeze in reply to todd hamilton, 03-19-2004 18:39:24
Usually you can sort of "run it 'til it stops". Then let it sit a few minutes. By then the engine should have enough heat to melt it and away you go. This is why aircraft have a carb heat system. They're a refridgerator
