case vac 14
chopper
03-18-2004 21:02:08
I have a 1956 case vac 14 and was wondering if a eagle hitch from a 1950 case vac would fit on it????
Jim
03-20-2004 08:04:20
 Re: case vac 14 in reply to chopper, 03-18-2004 21:02:08
Well, my late model is 6012578, and if you look in "Full Steam Ahead", they list mine as a mid production 1954, and the nice boys at CASE told me mine was made on June 16th, 1954. The VAC eagle hitches interchange to a point. They used two different pin sizes for the lift links, and two different style eagle claws/latches, plus they changed the lift arm mounting brackets, but by all means, it should bolt right on.
mj
03-19-2004 15:50:24
Ditto to "vac Lee"'s post. The "combine the first 2 digits of the serial number and subtract four" system of numbering went out the window in 1954.
ted
03-19-2004 01:01:06
Unless I'mm missing something Case never made a VAC in 1956. Please check your serial number. If it starts with a 56 then it is probaly a 52. And if that's the case, yes a 50 eagle hitch should work just fine.
chopper
03-19-2004 11:22:43
 Re: Re: case vac 14 in reply to ted, 03-19-2004 01:01:06
my case vac 14 serial number is 6001001 which tells me its a 1956, what do you think
dctom
03-19-2004 13:15:46
 Re: Re: Re: case vac 14 in reply to chopper, 03-19-2004 11:22:43
1955 WAS THE LAST YEAR FOR VAC-14, THERE WERE A FEW VA-VAH -AND VAI IN 1956
Nicholaus Sowder
03-19-2004 12:37:23
Chopper The serial number you have is when they started making the newer Vacs and you can't subtract four like on the earlier ones. I don't remeber how you figure your serial number but someone on here does. Thanks
chopper
03-19-2004 13:14:10
 Re: Re: Re: Re: case vac 14 in reply to Nicholaus Sowder , 03-19-2004 12:37:23
ok now im confused, the metal tag on my dash says case vac 14-6001001 can anyone give me an accurate year on this thing, ive looked at the serial numbers section and others keep telling me things like 52 - 56 but how do I get an accurate year?? any help please
dctom
03-19-2004 13:18:55
 Re: Re: Re: Re: Re: case vac 14 in reply to chopper, 03-19-2004 13:14:10
CALL RICH TWOREK AT CASE 262-636-7274 AND ASK FOR THE BUILD CARD FOR YOUR TRACTOR, YOU CANT USE THE OLD METHOD OF TELLING YEAR ON THE 60 NUMBERS,WHICH STARTED IN 1953 TOM
Leroy
03-19-2004 15:10:20
 Re: Re: Re: Re: Re: Re: case vac 14 in reply to dctom, 03-19-2004 13:18:55
Would this work for build card for RC, SC, DC as well?
dctom
03-19-2004 16:26:50
 Re: Re: Re: Re: Re: Re: Re: case vac 14 in reply to Leroy, 03-19-2004 15:10:20
YES HE WILL SEND YOUL A COPY FOR A FEE
chopper
03-19-2004 14:05:03
I have added a photo under tractor photo's named chopper
vac Lee
03-19-2004 15:33:00
 Re: Re: Re: Re: Re: Re: Re: case vac 14 in reply to chopper, 03-19-2004 14:05:03
According to my serial # chart it should be a late 53. The 54's start with 6011001
