general 730 questions
howdy
03-18-2004 12:38:30
couple of questions. WHat differences are there between the 730/830's with the air cleaner on the side and those with the air cleaner in front of the radiator. It is NOT a comfort king. ALso if the eagle hitch top link connects to the PTO cover on these tractors how do you use PTO driven eagle hitch implements???
Jim B
03-18-2004 18:08:49
 Re: general 730 questions in reply to howdy, 03-18-2004 12:38:30
On my 800D I use a 3-point mounted 200 gallon sprayer with a PTO driven pump. Of course the upper link bolt-on casting, which covers the PTO shaft, must be removed. I simply connect the upper link to the (higher) lugs above the hydrualic control valve. I believe it is for the bigger category 3-point tools, but it works OK.
