Temperature Gauge for VAC
Warren
03-17-2004 15:48:20
Hello Everyone,
I have a 1951 VAC. The wire for the temperature gauge has been broken and gone for a long time.
It is a solid wire with some kind of covering over it. How does this gauge function? It is electrical right? What type of wire should I use to replace it?
Thanks,
Warren in VA
Joe (Wa)
03-17-2004 19:34:33
 Re: Temperature Gauge for VAC in reply to Warren, 03-17-2004 15:48:20
If you mean the original type temperature gauge the tractor came from the factory with it is actually a bourdon tube pressure gauge. The �wire� is a capillary tube with a small bulb on the end. The bourdon & capillary tube ass'y is charged with a gas/liquid and sealed as a unit. When the engine heats up the gas/liquid mixture in the tube it expands and exerts a pressure in the bourdon tube in the gauge tending to straighten it. The end of the bourdon tube is connected by linkage to a spindle with a pointer. The pointer sweeps the gauge face marked in degrees relative to the movement of the bourdon tube.
They are generally called mechanical temperature gauges. If the capillary tube is cut or some how loses the gas/liquid charge, the gauge is not economically repairable. Most instrument repair shops stopped working on them in the �60�s. I did see a web site that would do it in a special case but for some very serious bucks. I believe that was �Gauge Boys� or a similar name if you want to do a search.
Joe
Warren
03-18-2004 09:02:36
 Re: Re: Temperature Gauge for VAC in reply to Joe (Wa), 03-17-2004 19:34:33
Thanks for the info but now what are my options?
You said a key word 'EXPENSIVE'.
Thanks
Joe (Wa)
03-18-2004 10:57:08
 Re: Re: Re: Temperature Gauge for VAC in reply to Warren, 03-18-2004 09:02:36
You can buy 2" generic mechanical temperature gauges at some auto, truck, farm supply stores. Buy glass lens type, plastic doesn't stand up well.
If you want an after market Case badge gauge they come up on ebay often. A couple of regular posters on this board sell them also.
Joe
