Does anyone have a good used rod for a Case Vac?
Nicholaus Sowde
03-17-2004 11:37:56
Does anyone have a good used rod for a Case Vac? Will a engine out of a Case Vac 1949 model fit in a Case Va 1944 model? I have a chance to buy a Va for $150 with a hole in the block. It has 24 inch tires on the rear and a belly sickle bar mower. I think it is basically a parts tractor. What do you all think. Thanks
BLR
03-18-2004 21:31:56
 Re: Does anyone have a good used rod for a Case Va in reply to Nicholaus Sowder, 03-17-2004 11:37:56
Nicholaus,
I should have a rod if you decide you need one
Art
03-18-2004 03:16:15
24 inch tires on that would make that a VAI...The rods should fit....Also the pistons should be steel in that VAI...Art
