Vac High pressure cylinder
Mike
03-17-2004 05:55:29
Have any of you had to replace the cup inside the cylinder? Mine is shot. My grandfather has been on a hunt for another but apparently Case doesn't make them anylonger. He got some bright idea to use a cup from a brake calliper. found one with the same diameter. I have know idea if it will work as the tractor is still not reassembled. Whats everyone think, think it will work?
seshns
03-18-2004 15:09:20
 Re: Vac High pressure cylinder in reply to Mike, 03-17-2004 05:55:29
I purchased an after market replacement cup from Moreta Equipment, Greeley Colorado 970 351 6400, cost 7 or 8 bucks, Good luck
Joe (Wa)
03-17-2004 13:06:49
The new p/n for that cup may be A30544. That p/n is still active. The old p/n is VT4107. Fits cylinders VTA731 & VTA2744 for 1944 through end of 1948.
A case dealer should be able to use those numbers and come up with the right cup.
Joe
Ross
03-17-2004 11:06:25
I'm using this set up right now. I'm using a 1 1/2" end of a wheel cylinder. The bad news the cup doesn't hold up to hydraulic oil very well or very long. Other than that it does work.
Ross
Bill
03-17-2004 06:38:44
Mike, Go to napa and ask to look in ther wheel cylinder cup assortment box, and just match one up. I forget the size right now but it will only cost you about 2.00 for a cup. Bill
