SC Case timing
JW2
10-03-2006 12:45:56
Have a SC Case that I am trying to get running again. There was no spark so I cleaned up the magneto and now have spark again. I did my best to time it again. Have the D on the flywheel in the sight window and the magneto set on 1. But I can not get it to fire. Seems to be getting gas. Is there something I am missing?
C. Amick
10-03-2006 13:32:03
 Re: SC Case timing in reply to JW2, 10-03-2006 12:45:56
You should have the punch mark on the flywheel visible in the sight window when the magneto fires. The No. 1 piston should be 1/2" before top dead center.
Walt Davies
10-03-2006 13:29:41
You are most likely 180 off check to make sure that number 1 is top dead center on compression stroke. Pull plug and stick finger in hole to test for pressure. Don't loose finger in hole when piston comes up.
Also go to this site to see all there is to know about your Magneto including the timing of it.
Link
Walt
