A couple of guys emailed, and wanted an update on our "little project" (sorry for the long post...)We have a diesel 830 CK, with case-o-matic. We needed (at least) the top end of the engine, along with misc gauges, a rear tire, etc. to get that tractor going. We decided to purchase another 830, and use our original 830 for parts. About a week and a half ago, it was delivered to a friend of ours, who is helping us (more like we are helping him a little) get it going. The seller told us that this 830 we just purchased "probably had a cracked head and the case-o-matic went out on it", as it could hardly pull itself. So, we didn't think it would take a huge effort to repair or replace a head, and fix the COM. Boy, were we ever taken... On this "new" tractor, 3 of 4 sleeves were cracked. Some 20 years ago, the tractor was overhauled, and wasn't put back together properly. I heard through the grapevine (after we had it apart, of course) that this 830 dyno'ed at 40 HP right after the overhaul, and has never run right over the past 20 years. The COM clutch was assembled improperly (that's why the tractor couldn't pull itself). The tractor was run hot, and run hot a LOT. Now, after cutting the sleeve counterbores, our friend found that three of the 4 counterbores are cracked. So...the heads may be salvageable (still at the machine shop). We may end up using the block out out original 830, as I think it's in good shape. We also are using the COM pump, the front end, and a couple of other parts from the original 830. In hindsight, it may have been better to have used this "better" tractor as a donor to our original 830! So, I guess that we were taken big time, but oh well... we are now in the process of getting parts ready to sell, such as the grille, hood, side panels, etc. Let me know if you want anything. A lot of parts on the 830 we had originally are in really good shape, as it turns out.
