Case, Oliver, or DB
mike
07-09-1999 12:07:26
I am in need of a tractor to primarily move and feed big bales and brushhog pasture ground. I've located 4 Case 30 Series (730,830, 930,1030) about 200 miles away but a recent dealer ad had a DB 770, 880, & 990 along with a 1600 Oliver, gas for sale. What the opinions out there. Which is the most reliable, has fewest problems, had parts availability, price, etc. ect. Need some straight poop. Thanks
Don L.
07-11-1999 06:51:32
 Re: Case, Oliver, or DB in reply to mike, 07-09-1999 12:07:26
For a Lot of reasons, Plain and simple, buy the Case 930 first, or the 830/730 secondly. Don L.
Barry Small
07-10-1999 23:13:24
I forgot to add this earlier, but those Olivers are good tractors.I don't know where you live but if you have hard winters but don't need to work your tractor to hard, a gas tractor should be considered for its ease of starting.
Barry
Barry Small
07-10-1999 23:07:23
For my money the 930 Case is the only way to go.That tractor will do it all. It may be a little bigger than what you want, but it will pull a triple bush hog with ease,and move round bales like they're not even there. If you ever get to do some serious plow work you will see it shine. Running a big round baler is no problem for the 930 either.Its a better tractor than the smaller 30 series Cases, and more plentiful than the 1030. Parts are easily found for the 930, and are no more expensive than any others. The only problem I see is the resale on 930's is always much lower than what they are worth. In S.W. Missouri a 930 is worth $3500.00. I don't remember the last one I loked at that wasn't that price.
Barry
mike
07-12-1999 11:53:06
 Re: Re: Case, Oliver, or DB in reply to Barry Small, 07-10-1999 23:07:23
Barry,
Checked with the dealer who had a 930 but it's gone now. He did have a 830 Diesel, WF, 3pt for $4,100, a 1030 Diesel for $5,200 and a 970 Diesel, 8 speed for $5,900. What's the deal on the 970? Newer version of 930? Being newer do they start any better in the winter? Also found a 730 but I not sure about them either. Thanks
Jerrie Lott
07-12-1999 16:31:06
 Re: Re: Re: Case, Oliver, or DB in reply to mike, 07-12-1999 11:53:06
970 is same engine as 930 but has newly designed heads that are direct injection instead of power crater like the thirty series also a little higher compression, bigger water pump so they cool better. Yes they start better in the winter. I think he is way high on his prices. The 830 would have to be cherry to be worth $3000 and the 1030 would have to be cherry and have a cab to be worth $4500. I don't know exactly what the 970 is worth but I know my brother just bought a 1070 with power shift, a cab with air conditioning about 30% rubber for $4300. We live in N.W. Illinois, so maybe they have a lot more value where you are, I don't know. Hope this helps. Jerrie
Redneck in AL
07-10-1999 19:05:53
I have a DB 990 and really like it. However it is probably no more dependable than any of the others. I would recommend going with one that has a dealer close by. There is a fellow up the road that rebuilds David Browns which is the main reason I have mine. Hope this helps some. Good luck.
Jack Willis
08-10-1999 01:42:01
 Re: Re: Case, Oliver, or DB in reply to Redneck in AL, 07-10-1999 19:05:53
I have a David Brown 885G (gas)which I bought very cheap. I have used it several years with some luck. Yet the parts are scarce and very expensive. Sheet metal is almost non existent! Some engine parts are available from Case dealers. My advise is to buy an American made tractor for which parts are available. Save yourself some heartaches and problems. Besides the hydraulics on the DB are weak!
