Looking for Antique Case dealer in area....
Roger
03-14-2004 20:00:21
I live in Arlington, Washington...
Have heard that there is someone in area who deals in antique Case parts, cannot find listing for... anyone know ? Need whole water pump for a "51 Case engine serial # 72 E 06156 outside serial # VAC 556240. Also have problem with "dry" clutch not working properly.
Dug G.
03-15-2004 18:54:44
 Re: Looking for Antique Case dealer in area.... in reply to Roger, 03-14-2004 20:00:21
Check under the tractor parts section of this site. You can also get them thru A&I also. I purchased one in December and works good. Make sure you get the right casting number, or ou may have problems with your pulley. As for your rear seal, open the clutch inspection plate on the side and seeif your getting oil in the bellhousing. It could be a leaky input shaft seal or a leaking rear seal. Good luck.
