VAC year?
Bruce fro Bould
03-14-2004 19:11:40
I have a VAC with the serial number plate missing. The grill is the old style (horizontal slots on each side of the center vertical strip). Can anyone help me identify the year. On the right side of the motor block there is a stamp that looks like two sets of two numbers 10 14 (stamped upside down).
Art
03-16-2004 03:12:23
 Re: VAC year? in reply to Bruce fro Boulder, 03-14-2004 19:11:40
Morning Bruce....If you look at the bottom of the valve cover , if the lip is turned down, that is an indication that it's an early version...The turned up version was made after 1947 I believe...Also if it has an eagle hitch it was made after 49
Bruce from Boulder
03-16-2004 16:52:53
 Re: Re: VAC year? in reply to Art, 03-16-2004 03:12:23
Art, thanks for the info. I'll check the valve cover next time I'm out at the barn. It doesn't have an eagle hitch but it does have a three point hitch (after market?). It does have the original hydrolic pump and the rocker lift, so it may have been modified from eagle to three point.
This VAC was given to me as another restoration project by friends. The husband said it was a '47, the wife said '49.
Steve from PA
03-15-2004 13:13:10
Bruce;
There are alot of guys on here who can help you narrow down the year, but they'll need more info. If you could post a photo, It would make it even easier for them. Hope this helps.
