LA manifold gaskets/ exhaust manifold ; need help
Poppinjohn720
03-14-2004 19:05:32
Im looking for a set of manifold gaskets for a LA Case. I also need a good (not cracked) exhaust manifold for the same beast. I need your help. Thanks!
Robert Pence
03-30-2004 09:42:17
 Re: LA manifold gaskets/ exhaust manifold ; need h in reply to Poppinjohn720, 03-14-2004 19:05:32
I got all the gaskets I needed to overhaul my L from Otto Gas Engine Works ([email protected]). I'm pretty sure they're the same for L and LA.
george md
03-14-2004 21:14:16
Poppin, As many LA's as there are out there , some one should have one . If you don't find one ,they are quite repairable with oxy/acet cast iron weld. Here is a link to some pictures of manifold repair . www.imageevent.com/gmachine Email if you need help.
george
Frank
03-15-2004 03:09:27
 Re: Re: LA manifold gaskets/ exhaust manifold ; ne in reply to george md, 03-14-2004 21:14:16
As of last fall, when engine work was in progress on my LA, all the gaskets and ferules were available from my local Case IH dealer. (Alderman's Equipment in Lennon MI 810-621-4201) Did not require or ask about manifold itself
