Info on a Case 431 Diesel
JK
03-14-2004 18:57:58
A friend of mine is interested in buying a 431 Diesel adjustable wide front tractor. Neither of us are that familiar with this brand or model and are looking for any info we can find on these. The tractor has a great body and tires are still good. The motor has a rebuild job that was performed about 2 years ago. It's a 2 owner tractor and has supposidly been babied all its life...so says my friends cousin who owns it. The only down side to all of it is that it has slow hydro. on the rear lift. I havent cranked it yet (dead battery) to check all of this but i figure its just from setting so much. Possibly the pump is going bad. Does anyone have a suggestion on this? Are pumps expensive to rebuild? How hard are parts to get for this tractor and is it a good model to own? Also what would a tractor of this sort with 4500 hours on it be worth? Thanks for any help on this!!!
Brent Behner
03-15-2004 19:05:56
 Re: Info on a Case 431 Diesel in reply to JK, 03-14-2004 18:57:58
JK Is It A Eagle Hitch Or Draft-o- matic Tractor. D.O.M. Tractor Has A Round Ball At Back Of Lift Arms. On Hydraulic Change Filter & Check Oil In Torque Tube, Hex Plug On Left Side Middle Back Of Torque Tube By Hand Clutch Lever. Should Get OPP.& Service Manuels From CASE IH. Dealer. If D.O.M. Valve Has Lowering Speed Screw At Back Of Valve, But Could Need Control Valve Cleaning. Brent
