need 530 hyd imfo
Rick
03-14-2004 11:01:29
I have a 530 model 541 that has draft-o-matic 3 point on it the 3point will raise but will not lower I took the valve apart & found that the lowering valve adjusting screw was backed out & the lock nut was laying in there on top of the ball I would like to know where the adjusting screw should be set this must have a factory setting from new THANKS RICK
