Clutch for a '51 VAC
Roger
03-14-2004 10:47:59
Does the clutch need fluid ? If so where does it get put in?
Joe (Wa)
03-14-2004 18:30:21
 Re: Clutch for a '51 VAC in reply to Roger, 03-14-2004 10:47:59
Tractor has a dry clutch. Joe
Roger
03-14-2004 19:33:27
 Re: Re: Clutch for a '51 VAC in reply to Joe (Wa), 03-14-2004 18:30:21
If the clutch is dry why would it work one day and not work the next day and have very little play in it now?
Joe (Wa)
03-14-2004 21:42:28
 Re: Re: Re: Clutch for a '51 VAC in reply to Roger, 03-14-2004 19:33:27
I assume that the clutch will not disengage being that is the most common complaint. If so there is a rust build up on the friction plate that is bonding it to the flywheel. If the lining is not worn out, you can generally knock most of it off by slipping and jumping the clutch. If the tractor is in regular use the problem will go away with time. When the tractor is not in use, keep the clutch pedal depressed with the lockout latch.
If the lining is worn thin, you will have to split the tractor and replace it.
If the above is not the problem, please post some specifics so someone here can try to identify the malfunction.
Joe
