water pump for a '51 VAC
Roger
03-14-2004 10:46:25
Need new water pump for my "51 VAC, part # on original is VT327. In researching part #A148401 does not look like the original. Where can I find the correct pump. Need new, the housing is gone.
Joe (Wa)
03-14-2004 18:14:51
 Re: water pump for a '51 VAC in reply to Roger, 03-14-2004 10:46:25
Roger,
VT327 is just the pump body. There were 3 water pump body styles for VA's late '40's through end of production. If your engine serial nr is 72+letter+5 digits the complete replacement pump is VTA908. That number has been superseded. I have A148401 penciled in for my '53 Vac as cross-ref but never did confirm. Maybe a Case dealer or someone here can.
300 series with G148 engine is the same pump if that is any help.
Joe
Richard Shackelford
03-14-2004 14:08:02
Hey man,
A fellow gave me this number for some parts for my 52 vac.The mans name is ED Axthelm he lives around the columbus ohio area (419-864-4959)Good Luck....Richard
Roger
03-14-2004 19:54:05
 Re: Re: water pump for a '51 VAC in reply to Richard Shackelford, 03-14-2004 14:08:02
I live in Arlington,Washington.
Does anyone know of a place in these parts that deal in old case parts. Have heard there is, but can not find listing for.
Joe (Wa)
03-14-2004 21:23:08
 Re: Re: Re: water pump for a '51 VAC in reply to Roger, 03-14-2004 19:54:05
Draper Tractor in Garfield, Wa lists the A148401 water pump in stock. Click on the link below and scroll down to the list of tractors it fits (note Vac after 1948). Confirm the application before you order. Be a good idea to have the serial nr of your engine when you call. 1-800-967-8185.
The following post is a link to Case parts vendors in Wa.
Joe
Joe (Wa)
03-14-2004 21:25:14
 Re: Re: Re: Re: water pump for a '51 VAC in reply to Joe (Wa), 03-14-2004 21:23:08
