I found a Case Cc that the man says will run on ei
Nicholaus Sowde
03-14-2004 08:10:20
I found a Case Cc that the man says will run on either gas or diesel. Item #3709784291 on EBay. I emailed him telling himit would ruin the engine but he hasn't changed it. You all should look at it just for $2,500 its a steal wouldn't you all say!!!? Its does have steel wheels on it. He says it is a 1933 model Cc. I think I will let him keep this rare machine that runs on Diesel. Thanks
Mike Schotte
03-14-2004 10:04:18
 Re: I found a Case Cc that the man says will run o in reply to Nicholaus Sowder, 03-14-2004 08:10:20
I wouldn't buy ANYTHING expensive from a seller with zero feedback and who can't even take the time to put in a description of the condition of the item.
The only way that auction description could have been any shorter is if he'd said "tractor."
A prime example of "buyer beware".
-Schotte
Paul
03-14-2004 09:13:23
A case cc is an all fuel machine and will run on white gas, gasoline, distilate,or kerosine. kerosine jetA or #1 diesel are all very similar.so yes it will run on #1 diesel.Will it run on #2 probably but the engine will have to be 200 plus degrees. is it worth $2500? probably not.cc's are getting scarcer every day though.Paul
CASEPOWER
03-14-2004 09:09:44
If it has it's low cost fuel manifold, and you can get it up to opperating temp. it will run as good on diesel as it will TVO (tractor vaporizing oil), kerosene, or distillant 1 & 2. They are all the same with more or less refinement. I have ran some or diesel and it won't hurt a thing.
