Decal aplication
RandyD
03-14-2004 07:23:37
Okay men, it is time for me to put my Mylar decals from Wacker on my Case SC. The paint is NAPA acrylic enamel with hardener with a 6-month cure since it's application.
Wacker said use acetone to clean the surface before putting the decal on. That seems a bit harsh to me. I was thinking using alcohol.
Any tips on the application of Mylar decals?
Thanks for the help
Randy
Mike Schotte
03-14-2004 12:18:31
 Re: Decal aplication in reply to RandyD, 03-14-2004 07:23:37
Hey Randy,
I can't wait to see them on. With your usual attention to detail- they should look great.
I knew you waited a long time for the decals to arrive... but I never thought about needing to let the paint off-gas and cure for a certain period, too.
Please let me know when you've got new pics. I'll be doing the same thing myself before April.
-Schotte
RandyD
03-14-2004 12:36:56
 Re: Re: Decal aplication in reply to Mike Schotte, 03-14-2004 12:18:31
Thanks Mike, I took her out yesterday to pull a downed pine tree off and it sure looked good. The magneto tips helped get it going again. I used a piece of 1200 grit sandpaper to pull through the points and got them clean. Got a nice big spark now.
Randy
dctom
03-14-2004 09:34:14
I ALWAYS USE WINDEX,, WASH AND DRY GOOD SHOULD BE NO PROBLEM
Randy
03-14-2004 12:38:48
 Re: Re: Decal aplication in reply to dctom, 03-14-2004 09:34:14
dctom did you install the big long stickers on the hood wet or dry?
