Did you ever see one of these?
ted
03-14-2004 02:17:43
third party image
Did any of you guys notice this hydralic pump on a DI listed on EBay?? It looks like it uses engine oil with the retutrn going back to the crankcase. Is it possible for the pump to pull enough oil through the distributor mount? Anyone recognize the make?
Dr Cy Kosis
03-14-2004 05:18:07
 Re: Did you ever see one of these? in reply to ted, 03-14-2004 02:17:43
I think you're seeing things.
I see an ordinary hydraulic pump sandwiched on the Mag/dist drive.
What it probably is, is that the lower line is attched to the pump with a ninety degree fitting to facilitate straighter routing of the line. The angle the photo is taken from just happens to line up well with the bump on the side of the crankcase adding to the appearance the the line returns to the block. The upper line looks like it would be pressure while the lower line would probably be return based on its larger size.
There'd be no oil flow to be had through the distributor drive. Theres very minimal flow even to the govenor housing.
ted
03-14-2004 14:51:24
 Re: Re: Did you ever see one of these? in reply to Dr Cy Kosis, 03-14-2004 05:18:07
Thanks Doc! I knew it could work, but my eyes sure deceived me.
robert
03-14-2004 03:16:11
that is the most cobblelus looking thing I've ever seen,did the tractor by chance have baler twine in action doing strange and useful things???
Eric Rylander
03-14-2004 18:48:53
 Re: Re: Did you ever see one of these? in reply to robert, 03-14-2004 03:16:11
What's so cobbled about it? That's a clean method of adding LIVE hydraulic to a tractor that never had it, My friends's dad's '49 DC has had that type of pump mounted on it since he bought it in the early 70's.
Eric
Dave_D
03-15-2004 09:55:23
 Re: Re: Re: Did you ever see one of these? in reply to Eric Rylander, 03-14-2004 18:48:53
Looks good to me. Is this a custom part or an off the shelf item? Also wonder if you could run a FE load with this?
Thanks
- Dave
Eric Rylander
03-15-2004 13:54:38
 Re: Re: Re: Re: Did you ever see one of these? in reply to Dave_D, 03-15-2004 09:55:23
A loader is exactly what my friend's dad runs on his. My memory is fuzzy since I was about 12 when I last saw his tractor, but there is a rectangular resevoir maybe 6" X 6" X 12 or 14" tall located on a bracket behind and above the belt pulley, and he has a spool valve within reach to operate it. It was on the tractor when he bought it.
Eric
