CASE 830 on ebay??
John Saeli
03-13-2004 18:02:19
Hey Fellas! Would someone tell me what is on the Intake Manifold of the 830 Diesel on ebay. #3802759100
John H-WI
03-14-2004 04:47:06
 Re: CASE 830 on ebay?? in reply to John Saeli, 03-13-2004 18:02:19
Back in the early 60's when pulling used to be stock all the green guys started doing this for more power. They would start out and open the valve just enough to give it more snort. The folks in charge had to put a stop to it as usual one thing leads to another and it ain't stock very long. One funny incedent though, there used to be a separate class for gals and this guys wife was pulling his "stock" 4000 and she turned the valve all the way on and man, you should have seen the smoke and fire out the stack. Killed it about 25 feet. When the guy got it running again and did his first pull he blew the turbo and a few other things inside. Couldn't really feel sorry for him!
Jake
03-13-2004 22:21:33
Does anyone know if all 830s used this same instrument cluster. The 830 is the only tractor to have this style. What is the name of this one? Thanks Jake
John Saeli
03-14-2004 10:34:39
 Re: Re: CASE 830 on ebay?? in reply to Jake, 03-13-2004 22:21:33
Hey Jake: That is an Autolite Cluster. Very similar to the S-W. They first appeared on the 1960 models.
SHeiserman
03-14-2004 06:25:27
My 830 has a different layout. The owner's manual doesn't even show it. Mine has 4 warning lights (filter, hot converter,oil, generator). The only gauges are temp, clutch pressure, and fuel. The bottom left corner is the speedometer, bottom right is the tach.
tinman
03-13-2004 19:55:40
looks like someone was adding some LP to the mixture. Like CASEPOWER said,wakes her up fast.
Roger
03-13-2004 19:00:46
It is definately a Century LP regulator. Like dctom said, for more power.
Old Eb
03-13-2004 18:20:07
Not sure what you are referring to John? The intake manifold is on the side we can't see (with the air cleaner), is it not? Are you referring to the silver/aluminum item on the picture side? If so I am betting it is the injection pump without most of its paint.
third party image
Old Eb
03-14-2004 06:59:52
 Re: Re: CASE 830 on ebay?? in reply to Old Eb, 03-13-2004 18:20:07
I see now - was only looking at the first pic.
third party image
dctom
03-13-2004 18:10:23
JOHN LOOKS LIKE SOME KIND OF A REGULATOR, WHAT FOR I HAVE NO IDEA, ALMOST LIKE A LP REGULATOR, MAYBE HE INTRODUCED LP WITH DIESEL FOR MORE HP
John Saeli
03-13-2004 19:02:14
 Re: Re: CASE 830 on ebay?? in reply to dctom, 03-13-2004 18:10:23
Hey DCTOM: It sure do look like a LP Reg. but I couldn't figure why it'd be on an 830D. Never heard of doing that for power. Wonder how it would work for Cold Weather Starting?
CASEPOWER
03-13-2004 19:17:52
 Re: Re: Re: CASE 830 on ebay?? in reply to John Saeli, 03-13-2004 19:02:14
LP injected in a diesel is like putting NOS to a gas engine. Wakes it up fast.
