HELP!...Rebuilding An SC Adj. Wide Front!
Glenn FitzGeral
03-12-2004 09:39:52
Rebuilding an Adj. Wide Front for my SC. The king pins are pretty loose in the vertical cast housings. Are there supposed to be bushings in there? Have any of you tried to tighten yours up? Any help is appreciated?
Glenn FitzGerald
03-13-2004 20:08:08
 Re: HELP!...Rebuilding An SC Adj. Wide Front! in reply to Glenn FitzGerald, 03-12-2004 09:39:52
Thanks guys. Sorry they're not still available from Case. I will check with our long time Case dealer just in case...!
John Saeli
03-13-2004 05:22:33
Those bushings are not available from Case. I have a blueprint with the dimensions. Anyone with a "MSC" book can order a stock bushing that should work. I'll get back with the diminsion.
ted
03-13-2004 00:17:34
Glenn, my parts book shows bushings, 2 for each side, part no. 03430AB1. It dosn't give any dimensions, but if you can get good measurements a machine shop should be able to make some for you, for some$$$. Who knows, try the CaseIH dealer, maybe you'll get lucky.
