Sc clutch brake
Mike Schwartz
03-10-2004 21:12:36
Hello, I am looking for the material that acts as the clutch brake on the belt pulley. Not exactly sure what this is called. Mine is worn down to the cast on one side so I am not even real sure what size it was to start with. Local dealer has not had any luck trying to locate a replacement. I did luck out and find a case model V pull combine which looks to have the same engine as the SC to get parts off of today so the rad/gas cap search ended. Thanks for your help, Mike(WA)
ScottCT
03-11-2004 15:44:36
 Re: Sc clutch brake in reply to Mike Schwartz, 03-10-2004 21:12:36
I have found an easy (not to mention cheap) way to fix these. I use a piece of 2" leather belt material like the old flat belts used on the C's for the fan. I drill the holes to line up with the holes in the cast, then counter sink them slightly using a larger drill bit and rivet them in with copper rivets to avoid damage to pulley. I have redone several like this and never had a problem. It may not be purely original, but I defy you to tell the difference once it's back in place.
Les
03-12-2004 05:01:05
 Re: Re: Sc clutch brake in reply to ScottCT, 03-11-2004 15:44:36
That sounds just as good as what we did, Scott. Probably that leather wouldn't last as long as the asbestos but that wouldn't be a big deal.
Les...fortunate
03-11-2004 06:24:32
Well, here's what we just did on mine. It hasn't been tested by time yet but we'll see how it works.
A friend gave me a piece of asbestos material that is used for brakes. Gave me enough to make three of them little pads. Now the trick is to get it onto the cast piece and have it stick there. Sky's dad is in the flooring business and he has some glue that supposedly works on everything so that's going to be the first try.
If that doesn't stick, copper rivets will be the next try. Notice that there are probably the remains of four rivets in your cast piece? Punch them out and reuse the holes for the new rivets.
Another possibility might be to get a piece of a regular brake shoe of the size you need and figure out a way to attach it. (Countersink, rivets)
Good luck.
Glenn FitzGerald
03-11-2004 05:24:55
My DC needs its clutch brake redone also. I haven't started on it yet but I figured I'd start at a shop that rebuilds clutches. If they can't do it I figured they could put me onto someone who can.
