case backhoe front end loader
big dave 1955
10-03-2006 10:39:36
just purchased what is supposed to be a 1969 case back hoe with front end loader, i cant find any info for it. tag on it says model case G530 serial# 8286901 the hyd.on the back hoe are very slow,also not sure were to check and add hyd. fluid oil or what kind.would also like to find a wiring diagram for it.any help would be great thanks dave
Phil (NJ,AZ,Sask)
10-04-2006 05:02:47
 Re: case backhoe front end loader in reply to big dave 1955, 10-03-2006 10:39:36
[quote]not sure were to check and add hyd. fluid oil[/quote]
The FEL Frame is the Tank (both sides) The fixed uprights are vented and have a pipe plug on the side (left) for filling. The small check plug, up near the the RAD, is removed and you fill the system until fluid flows out the check plug hole.
Hope this Helps,
