Case 830 info ???
Frank (IL)
03-10-2004 16:51:25
I want to put a loader on the Case 830 diesel. I found a Freeman 4000 loader and need to know if it will fit on the 830 and does the 830 have to much HP for that loader. What would be a fair price for the Freeman 4000 loader? Its in fair shape.
Roger
03-10-2004 19:57:37
 Re: Case 830 info ??? in reply to Frank (IL), 03-10-2004 16:51:25
I'm not sure about the Freeman, but I had an old arch frame Stan Hoist that was used on a lot of M Farmall's on our 830. I had to weld a 2 inch flat iron onto the front end of the mounts so the back end of the mounts would reach the rear axles. My 830 is a wide front so I couldn't mount it back any farther, the 830's are a long tractor!! Check the length to make sure the Freeman will fit first, even with some modification it may or may not.
