Testing temp gauge on 2390
Shane
03-10-2004 13:19:58
Just got a '78 2390 this week! Needs a few minor things though, one is the temp gauge isn't working. I replaced the sending unit but it does the same thing. Turn the key on and straight up above the red it goes instead of across or down some to the yellow or green. When you unhook the wire it goes straight down. Had the gauge out of the dash and it has 4 studs, 3 of which go into terminals for the power and whatever else. So how do I check the gauge. I don't think it is the wire since it changes when you hook and unhook it. Thanks in advance!
