SC generator amperage?
Kent
03-10-2004 08:47:27
I have an original generator on my SC, and recently it stoped charging. I am taking it down to a local shop to have it rebuilt today. When it did work it only charged about 8-10 amps. My question is this: what max output amps should this put out, so I know if it's working correctly when I get it back. It's a '43 SC with the orginal generator. Thanks,
Kent
Klyde
03-10-2004 10:11:54
 Re: SC generator amperage? in reply to Kent, 03-10-2004 08:47:27
Kent, 8-10 amps is fine. You can adjust the 3rd brush for more or less. If you are running he tractor all day 8-10 is too much, if the engine is still running with a mag. If you have a distributor 8-10 is good. Remember with a mag he only power used out if he battery is for starting and to run he lights. I still use my SC for full days and I have that one set for about 2 amps.
