There should be a fill plug on the shifter cover. When you pull it out, there should be a dipstick welded to it. If the dipstick is missing, post and I will measure mine so you get the right oil level. 90 wt is the original factory oil. Original factory engine oil was nondetergent and weight varied somewhat depending on which manual one is reading. Generally: SAE 10 for -10 to 32*F SAE 20 for 32 to 70*F SAE 30 for 70*F and above I use 30 wt detergent oil year around. Some guys here use 10-30 and other. I don't think it makes much difference unless the tractor is frequently cold started in near zero temps. Here are some more thoughts on you Eagle hitch. �There was a hex nut in another line next to the line with the square nut.Every time we would try to raise the 3-point air would force its way out of the hex nut.WE loosened it.Any clues� I just noticed this sentence in your above post. You may be referring to this tube. There is a 5/16� tube that runs from the bottom right side of the piston housing back to the torque tube, entering just forward of the transmission flange. The purpose of the tube is air vent and leak off line. When the hitch is raised the piston goes down in the housing. The air under the piston is vented into the torque tube and the reverse when the hitch is lowered, piston goes up, and air is drawn from the torque tube. The tube is also used to drain off any oil that leaks by the piston seals and incidental excess grease from the rock shaft housing. This tube sometimes gets plugged with hardened grease and its functions are forced to a much more restricted passage of the right side rock shaft bearing clearances. The effect is like a partial air lock under the piston is both directions and any oil that seeps by the piston will drip off the right rock shaft/control valve area. Joe
